Magnets
Discussion in 'Home Cinema Speakers' started by Spartacus, Dec 13, 2004.
  1. Spartacus
    Spartacus
    Nov 22, 2004
    103
    Quick question for the more technically minded of you.
    I have a dent in my metal speaker grill. One option is to "pull out" the dent via a very strong magnet.
    Does anyone know if this would harm/effect the magnets inside the speakers?
    Thanks in advance.
  2. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    A magnet shouldnt do any harm at all in my experience. Are the grills not removable?
  3. Spartacus
    Spartacus
    Nov 22, 2004
    103
    No they are not :( I tried to take the speakers apart but they are too well put together.
    Options are:
    1. Leave it
    2. Have a go with a powerful magnet.
  4. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    damn, I hoped that wasn't the case. How big are the holes in the grill? Any chance you could feed something like thin wire through to pull the dent out?
  5. Spartacus
    Spartacus
    Nov 22, 2004
    103
    thought about that - problem is the holes are VERY small. not saying it is impossible but would have to find some very strong/thin wire. (and repeat the process a lot of times :)
  6. Jules Tohpipi
    Jules Tohpipi
    Feb 4, 2004
    693
    43
    +143
    My fear would be that, if you were using a magent that strong, there would be likelihood of deforming the whole grille - or certainly other parts of it. If it's going to pull out the recessed bit, then won't it try to pull out the OK (less recessed) other areas too ?
    Depending on the cost of the speakers, how about taking it to a place that gets those little dents out of cars ? I don't know how the car people get those little dents out (for 50 quid), so maybe I'm taking tosh. But just a suggestion.
  7. Spartacus
    Spartacus
    Nov 22, 2004
    103
    I think they use a strong magnet m8 :)
    Thx for replies though.
    *off to ponder next move*
