magnet shielding
Discussion in 'Subwoofers' started by krusty, Feb 18, 2005.
  1. krusty
    krusty
    how close to a tv will placement of a rel q100e cause my tv to mess up, as ive heard the rels are not magneticaly shielded? is this correct?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    The answer is easy to find out as all you have to do is move the REL closer and closer to your TV until the colour staining on the picture is visible.
  3. Diamond
    Diamond
    Depends on the tv and sub, but mine are within 10" of each other. Tv is always placed higher, so that's not really a problem.
  4. roman-r
    roman-r
    Jun 11, 2004
    6,340
    83
    London - Stoke Newington N16
    +183
    Is it just colur staining that you need to worry about or can it create picture noise by either it's magnatism or it's electrics.
    Krusty, hope you don't mind me asking :)
  5. RohanM
    RohanM
    Jun 4, 2004
    357
    London
    +29
    Also depends on the telly - my Panny PD30 seems to be very sensitive (had to move my Q150e well away - over 4foot), but others seem to be less so...
