after spending hours sorting capture then edit i came to save as avi and the screen just froze . iwent to technical support on web and had a system check , it told me to remove direct x 9 and upgrade my sound and graphics drivers i did 2 of the 3 but since i use adobe encore to burn dvd i could not remove direct x 9 i tried again and same problem i gave up with magix movies on 2.0cd"dvd and went back to ulead 7 imported file edited and rendered but gave me a problem on 99 %of finish i have never had a problem with ulead before or adobe encore very peed off with magix (fastrak}something seems to have infected my os (xp)i was hopeing or not wishing that someone out there may have had simalar problem , it is easy to say why go with magix when you have ulead and adobe prem pro /encore but i found the kids could use magix hope you understand my problem , no editing suite i have at the moment seems stable if no one else as had this problem i would seriously advice people to stay clear of fastrak software on editing . i also believe you will get same problem from edit pro 2004 (magix)thanks for any input on subject in advance . dennis
