Magic Eye reset
Discussion in 'Satellite TV, Sky TV & FreeSat' started by stevebez, Aug 9, 2004.
  1. stevebez
    stevebez
    Jul 11, 2004
    493
    +13
    Trying to get my magic eye to reset itself and work again. Switched the digibox off to relocate and now the magic eye does not want to work - no matter what I do to connect it up.
    I remember in the past by fiddling around with plugging and unplugging I managed to get it working again ... not this time ... any suggestions as to getting it back on line?
    Rgds Steve.
  2. Pug72
    Pug72
    May 10, 2003
    2,226
    Hereford
    +375
    Check if thr RF2 output needs to be turned on.
    Services, System Setup....then press 0, 1 then Select.
    Now select 'RF Outlets' and make sure 'RF Outlet Power Supply' is set to 'On'.
  3. stevebez
    stevebez
    Jul 11, 2004
    493
    +13
    Thanks alot this did the job ... had to reboot as well though.
    Rgds Steve.
  4. Pug72
    Pug72
    May 10, 2003
    2,226
    Hereford
    +375
    My pleasure. Glad you got it sorted. :)
