I have a standard sky box set up that feeds two TV's. One via the RF out connection which is located in another room.
I have just recently bought a new TV (Sony KDL-26S3000) and connected it to the Sky box via the RF output.
Previously this worked fine with my magic eye and i was able to control the sky box.
However, since installing the new TV, i cannot access the sky features (SKY Guide etc) via the Sony TV.
I have checked the setings on my Sky box, and the RF output is enabled correctly. Also, i have tried numerous codes for the remote control, both supplied from sky and from the net.
The Sky tv will control the Sony TV's functions (Sound, Channel) but will not control my sky channel, even when i press the SKY button on the remote.
The magic eye works fine on my old CRT tv, and flashes correctly when a button on the sky remote os pressed.
Having searched the net people suggest that it is due to interfearance from the LCD tv and to move the magic eye away from the TV, however, this does not work either?
Does anyone have any ideas as to the cause of the problem?
Thanks.
Thanks.
