Magic eye problem
Discussion in 'Satellite TV, Sky TV & FreeSat' started by jayzeer, Oct 31, 2004.
  1. jayzeer
    jayzeer
    Jul 14, 2004
    27
    My magic eye for sky+ viewing from upstairs isnt working anymore - the red light on it doesnt appear. Bought a new one & still no red light, not working. Could I have just had a bad batch from the shop - go back replace or could it be another problem?
  2. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,008
    Southampton
    +233
    Are you sure it's not a sat box problem - RF2 outputs 9v to power the infra red receiver - maybe the sat box is at fault!
  3. Karma
    Karma
    May 20, 2002
    375
    Birmingham
    +11
    Box could have reset itself so that rf2 no longer outputs the 9v power (have you had a powercut or does anyone have fiddly fingers in the household?).
    I had a problem with my magic eye, but only occasionally. It turned out that the sun, at certain times of the day was flooding stariaght onto the eye and it couldn't "see" the remote control signal.
    K
  4. rooney
    rooney
    Mar 7, 2004
    506
    midlands
    +33
    the ouput needs to be acticvated in the service menu for it to work
  5. KeithO
    KeithO
    May 28, 2003
    1,432
    63
    Erding, Bavaria
    +214
    Had exactly the same problem myself last week, and tried exactly the same solutions. Turned out to be the cable. Over the course of the past 2 years, being trapped in the bedroom door evey night must have split the outer sheathing or something. Still had a picture, just couldn`t control the box from upstairs, and no light on the magic eye.
    Change of cable and hey presto...all is well again
  6. Zarch
    Zarch
    Jan 23, 2003
    3,531
    Sheffield
    +827
    To test if the magic eye's are working, plug them directly into the back of the didibox (rf2). Cover up the digibox remote control sensor and try changing channels! You should at least get the red light on the eye aswell.
    Good luck. :smashin:
  7. jayzeer
    jayzeer
    Jul 14, 2004
    27
    Thanks, I'll try that. What I do get from the cable upstairs is to watch whatever channel is on the Sky+ downstairs hence the cable is working but not the magic eye for me to change channels with.
