magic eye led on but not working
Discussion in 'Satellite TV, Sky TV & FreeSat' started by larry5, Mar 17, 2005.
  1. larry5
    larry5
    I had an old magic eye that worked fine since it's installation with sky+ 3 years ago. It suddenly stopped working although the led was still illuminated so i figured it was a problem with the magic eye. I bought two new magic eyes and have the same problem with both. I have tried connecting directly to sky+ box but again led lights up but does not change the channel. Can anyone advise what to do next?
  2. kennysatman
    kennysatman
    Mar 3, 2005
    is it the same remote you are using for both tv`s if not try the remote you know works, it could be a fault remote.
    it could also be a break/short in the cable check that out
  3. JayCee
    JayCee
    Jan 20, 2004
    23,989
    Lanarkshire
    +2,614
    I have come across a similar situation where the digibox was at fault.
    It cannot be a open/short in the cable as Kennysatman suggests as the led wouldn't light.
  4. larry5
    larry5
    yeah and the remote works fine with the front panel of sky+ box, so i guess it's a problem with the box.
  5. kiza
    kiza
    Nov 5, 2004
    53
    +3
    Try switching Sky+ off mains for a half minute. That might help!
  6. larry5
    larry5
    kiza after a couple of goes and then some random button presses of remote which didn't respond that seems to of worked thanks
