Magic Eye Cabling Join
Discussion in 'Satellite TV, Sky TV & FreeSat' started by BEDDAUBOY, Sep 21, 2007.
  1. BEDDAUBOY
    BEDDAUBOY
    Jan 5, 2007
    Hi Guys
    I have a SKY+ in the lounge and I want to be able to watch and control SKY in the bedroom. I have a cable that runs from the RF2 outside the house , up the drainpipe, along the guttering, and through the wall into the bedroom wardrobe. At some point in the past, before the magic eye idea, I needed to split the cable to go to another TV as well. That requirement has long since gone, but I am left with a join in the cable where it used to split. The magic eye does not power the red light on when connected to the television, but does on the lounge end of the join. Unfortunately the magic eye will not reach to the TV there. I am therefore stuck with the join. To rerun cable would be a very desperate last resort. What is the best way to enable the magic eye to communicate through the join?
  2. gw3xjc
    gw3xjc
    Sep 19, 2007
    13
    3
    Nr. Cardiff
    Ideally you would run another cable as you say. I would use two "f" connectors with a barrel connector in between. Thighten them up with a spanner and wrap the joint with self amalgam tape.
    I have used this method many times with coax cable.
    roger
  3. FRANTIC FRANC
    FRANTIC FRANC
    Aug 7, 2006
    1,375
    63
    +86
  4. BEDDAUBOY
    BEDDAUBOY
    Jan 5, 2007
    Nice one guys - I'll let you know how I get on!
  5. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +308
    Just a word of warning. Or two:
    The plug needs to be the correct size to match the cable.
    The method of fitting shown by the pictures in the eBay auction is incorrect.
    See http://www.satcure.co.uk/tech/fconn.htm
  6. FRANTIC FRANC
    FRANTIC FRANC
    Aug 7, 2006
    1,375
    63
    +86
    Yawn! Sam if you are so knowledgeable why on earth don't you get a job with Sky?
    Cheers, Franc
  7. BEDDAUBOY
    BEDDAUBOY
    Jan 5, 2007
    Doesn't work - Is this because the cable is coax?
  8. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +308
    You must use double-screened coaxial cable.
    I suspect this is simply rudeness but I'll answer the question:
    1. Because I'm retired.
    2. Because Sky pay low wages compared with what I could earn before I retired, since I'm a qualified engineer (a real one with a university degree).
  9. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,397
    Bradford, West Yorkshire.
    +325
    Hmm... Wondering why this thread has been revived from over nine weeks ago.... :confused:
    Is it;
    a. Because you missed it in your previous visits.
    b. Because you're looking for an argument
    c. You were in dire need to pontificate on the forums. Again.
    d. Trawl up a thread in which you had previously advertised Satcure, thereby giving them another free advert? As if the several hundred you'd given already weren't enough. :devil:
    My money's on a. And b. And c. And d.
    I'm sure you'll enlighten me.
    While we're at it...
    Since when did being an 'engineer' require a university degree?
    How much were you taught about 'Sky Digital' when studying for your degree back in the sixties?
    There's an argument here that, in some respects, FRANTIC may just know more than you Sam. :rotfl:
  10. matthewcarlrose
    matthewcarlrose
    Mar 3, 2007
    98
    11
    Wirral
    +8
    In the classic sense he might be referring to someone with BEng degree etc, ie Bachelor of engineering as oppposed to most who are simply just technicians!
    Whats wrong with dragging some threads back anyways....Better Late than never! :)
    Matt
  11. Tesla
    Tesla
    Dec 9, 2003
    943
    Bristol, UK
    +32
    I don't like the satcure method for fixing F connectors on. I think it's messy.
    I posted a guide on here once, I asked for it to be added to the sticky but don't think it ever was?
