Magic and pre made cable's
Discussion in 'Satellite TV, Sky TV & FreeSat' started by paul1967, Feb 6, 2009.
  1. paul1967
    paul1967
    Dec 26, 2005
    1,258
    48
    +65
    If you have a problem with fitting a magic eye and are using an aftermarket premade extension cable I have found some only allow the eye to work if the cable is plugged in a certain way ie the current only flows 1 way throught the cable ie plugged in eye direct to back of sky box works ,plug in premade cable does not turn cable around works you might have the fit an adapter to get it to fit.Hope this is some help to someone.
