macrovision removal?
Discussion in 'Blu-ray & DVD Players & Recorders' started by John Sparks, Jun 3, 2002.
  1. John Sparks
    John Sparks
    HAS ANYONE GOT EXPERIANCE WITH USING EXTERNAL MACRO REMOVAL BOXES ?, I'M AFTER A TOSHIBA 510 FOR £250 FROM RICHER SOUNDS BUT I DO NEED MACRO OFF SO I CAN SEND SIGNAL INTO A STANDARDS CONVERTOR ( WANT TO TAKE TOSH TO USA AND WANT TO WATCH MY REGION 2 PAL DISCS ON NTSC TV.WHAT IS THE QUALITY LOSS ISSUE WHEN USING THESE LITTLE BOXES .CHEERS. J.S.
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    for a start the quality is awful, then hardly any tv sets in the states will handle the 50hz signal of Pal anyway.
    you would be best to buy a $79 dvd player from bestbuy or somewhere when you get out there.
    unless you were thinking of buying a decent standrds convertor that changes the signal to a true ntsc 3.58 signal , but these are more money than the dvd player you are looking at.
  3. John Sparks
    John Sparks
    i should have made myself more clear , when i go to the U.S. i will be buying the Samsung w5000 convertor vcr , hence the need to feeed in a PAL signal without Macrovision so the Samsung can do its function correctly. I want/ed the Toshiba 510 as it has progressive NTSC o/p. The standards conversion is'nt to much of a worry It's the macro off and the possible quality loss that i'm wanting to resolve , i'm just worried of rubbish PAL in , rubbish NTSC out . I have only about 20 region 2 PAL discs which i still want to play but as time goes on my collection will be of course mainly region 1 , except for me getting UK stuff such as British comedy sent over..
    Thanks. J.S.
  4. roadtorode
    roadtorode
    The macromaster cable (£30ish from innovations !) does the job very well without extra boxes (the electronics is in the cable but it needs a power supply (provided))
