macrovision or not ????????
Discussion in 'Blu-ray & DVD Players & Recorders' started by Fonz, Dec 15, 2002.
  1. Fonz
    Fonz
    i have a bush multi region player i think its a bush 2000
    anyways i was wondering if this player had macrovision enabled as i remember reading on your review that it didnt?
    thanks
    Fonz
  2. john039
    john039
    Sep 17, 2002
    695
    West Midlands
    +75
    Easiest way is to try to record something from it.
    If it does it's macrovision disabled if it doesn't it's macrovision enabled.
  3. Fonz
    Fonz
    thanks for the reply
    i just tried that, and it seems to flash dark and bright, think its enabled then, any way i can disable?
    thanks
    Fonz
  4. mcunni1817
    mcunni1817
    Fonz,
    try here www.vcdhelp.com
    there is no macro hack for the bush 2000 but it does have hacks for other bush dvd players m8
    mark
  5. Fonz
    Fonz
    just checked its a bush 2004
    couldnt find any hacks on that site for it :(
    but my friend says i can get a cable that will diable the macrovision :)
    ill let u know how it goes
    thanks
    Fonz
  6. john039
    john039
    Sep 17, 2002
    695
    West Midlands
    +75
  7. Fonz
    Fonz
    thanks john
    seems you are right, just read another review which stated bush realising they had made a mistake (by it having macrovision off) started putting it on in other models !
    damn! :!
    nevermind eh?
    lol
    Fonz
