Macrovision on RGBS
Discussion in 'Blu-ray & DVD Players & Recorders' started by stanleyntl, Nov 26, 2004.
  1. stanleyntl
    stanleyntl
    Dec 6, 2003
    806
    28
    Worthing, Sussex
    +44
    Is the macrovision signal carried on the RGB output of DVD players?
    I assumed that only composite and svideo output was affected because this stops vhs/svhs recorders from copying discs; also most US DVD recorders only support svideo recording not component or RGB.
    If so, how? Surely component colour signals (R,G and B) and the sync line (composite) can't carry a macrovision signal too?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    composite sync is composite so will carry the macrovision signal have a search for SDI.......................................;)
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Macrovision is carried in the sync pulses, so it doesn't matter what format the video signal takes, it will be there.
  4. Video Filter
    Video Filter
    I can asure you that Macrovision is carried through the "Y" Components output of the "Y", "Pb, "Pr" signals. I have done many experiments with this.
    If you need a way to filter out Macrovision from components outputs, the Video Filter is the only device in the market that I know of, which allows you do do this.
    Sine I can't post sites for devices that do this on this forum, according to the moderator, you can write to me at [email address removed] and I will then point you to the website.
