Macrovision Hack for Matsui 125???
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by jimmibo, Jan 4, 2005.
  1. jimmibo
    jimmibo
    Hi all,
    I've searched the net high and low for this, but can't find one anywhere that works. I have a Matsui-125 DVD player - I've successfully hacked the multi-region to "ALL", but it still plays in black and white.
    So, it's probably a Macrovision problem. The only macrovision hack I see everywhere tells you to hit the "bookmark" button... but there ISN'T a bookmark button on the Matsui 125 remote! (I'm in the UK if this helps, maybe there are different versions?) The hack is:
    Insert a DVD
    Press Stop
    Press Bookmark
    Press Menu
    Press 5, 9, 7 then Exit
    Somebody said try the "Index" button instead of "bookmark", but this also does nothing... I'd be VERY grateful if anybody knows of a macrovision disable hack that works for this DVD player!
    Many thanks in advance,
    Jim
