Macro Vision
Discussion in 'Blu-ray & DVD Players & Recorders' started by Nexus6, May 27, 2002.
  1. Nexus6
    Nexus6
    Is there any firmware hacks to turn MacroVision off on a Denon 2800. I have applied the Pal Progessive Scan Hack and that works fine, I thought that this might also disable the Macro Vision signal.
    Thanks very much.
