Macro on Canon 50mm f1.8 - How to???
Discussion in 'Photography Forums' started by geofftelforduk, Jul 31, 2005.
  1. geofftelforduk
    geofftelforduk
    May 21, 2004
    1,248
    Northern Ireland
    +151
    Guys, as you know I purchased a Canon 50mm f1.8 MkII lens last week!!
    I was wondering if there is anything special I need to do to get the macro workin on it!!
    You see, I also have a Sigma 28-135mm and there is a macro switch which is on the lens!!
    Just a little confused!!
  2. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +22
    it aint a macro lens as far as im aware
    minimum focus distance is 0.46m if i remember
  3. geofftelforduk
    geofftelforduk
    May 21, 2004
    1,248
    Northern Ireland
    +151
    Oh right then!! I though I seen somewhere that it was! Doh, silly me! :oops:
  4. kenlynch
    kenlynch
    Jun 7, 2005
    111
    Rochdale
    Macro is nothing to do with focusing distance, it simply means the image on the sensor is the same size as the subject or larger. To get macro with that lens you would need to use it in conjunction with extension tubes.
  5. DJW
    DJW
    Aug 29, 2002
    965
    16
    You don't always need a macro anyway...take a look at the shot I entered in July comp to see how I gave up with macro on zoom lens & just took a tight crop from the 50mm 1.8 :)
  6. seany
    seany
    May 1, 2003
    2,987
    61
    Manchester city
  7. RobertP
    RobertP
    Nov 21, 2002
    522
    19
    Woodford Essex
    50mm works good as a macro....all you need is a reversing ring :)
  8. ASH1
    ASH1
    Mar 1, 2003
    1,208
    +61
  9. kenlynch
    kenlynch
    Jun 7, 2005
    111
    Rochdale
    What did you learn at school? 100x1.6=160, and I consider myself to be crap at arithmetic :D
  10. ASH1
    ASH1
    Mar 1, 2003
    1,208
    +61
    Well I did say 150ish :rolleyes:
  11. seany
    seany
    May 1, 2003
    2,987
    61
    Manchester city
    You have a better working distance with the 100mm if you don't want to disturb the critters. I'm not in to efs but i hear its a pretty good macro lens
