Macro Master
Discussion in 'Projectors, Screens & Video Processors' started by themoron, Feb 25, 2002.
  1. themoron
    themoron
    Jun 30, 2001
    234
    Christchurch, Dorset
    I was just browsing through a catalogue that came with the daily mail and saw this Macro Master will this actually help the picture quality though a projector or is this just a gimmick?
    themoron
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Just sounds like a macrovision disabler
  3. themoron
    themoron
    Jun 30, 2001
    234
    Alanrob
    Thanks for the reply, but it does say that it improves the picture when viewing on large screens, that sounds like it does more than just disabling macrovision. Any other thoughts?
    themoron
  4. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Some people tend to think that Macrovision does something to the picture. Can't say that I have noticed any change between a player with or without macrovision.
    Only way to find out if it's any good is to buy it and try it out for yourself, but I tend to think it's just another con to get your money.
  5. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    Always slightly worried when there are no real pictures of the item.
    MacroVision can cause a problem if you have only one SCART on the TV, so your DVD player is routed through the VCR then onto the telly. If this cable disables macrovision then it might be just the gadget for you.
    The correct device to remove sync jitter caused by Macrovision is a Frame Store Time Base Corrector, but the cost a little more than £29.99
    Personally, I think the real hook is
    "An impressive side benefit is that it allows you to make crystal-clear copies of DVD’s." Followed by the the big bold - You mustn't copy... blah, blah, blah - warning.
    Can't think who might possibly want to copy DVDs, can you?;)
    Regards
