macG4 to Sony wide screen
Discussion in 'Desktop & Laptop Computers Forum' started by marcoeser, May 8, 2001.
  1. marcoeser
    marcoeser
    Jul 17, 2000
    341
    Hi everyone
    I've had a question for awhile now, but I don't know if it's possible.
    Can I connect my new Apple Mac G4 which only has a VGA socket on back to my Sony KV-32fx60 which accepts RBG through the scart socket? If so what cable and where can I get one?
    Any ideas?
    Marc :)
  2. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    You will some sort of VGA to svideo converter. There are planty around for PCs but I don't know if they work on Macs.
  3. marcoeser
    marcoeser
    Jul 17, 2000
    341
    can I connect useing RGB, or do I have to use Svid? isn't the signal comming out of the computer RGB?
  4. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Sorry I'm not technical enough to tell you why you can't just use an RGB cable. I just know that some sort of conversion is required. I have never come across one that supports RGB. MrD could probably tell you.
    Jeff
  5. Matty N
    Matty N
    Hiya,
    can't think hard enough at the moment to propagate a full reply but just one reason why it will need conversion:
    Can you make your computer refresh at 25hz? Probably not. This means that the TV (which runs at interlaced 50hz on a PAL system) will be unable to cope with the minimum prob. 60hz from the PC. In addition, the PC outputs progressive scan video - ie each of the lines (equivalent to the vertical resolution) is output sequentially, whereas the TV is designed to accept an interlaced signal (lines 1,3,5 etc. on first pass; 2,4,6 on second; 50 times per second). Finally, the TV will be unable to support the resolutions of the PC.
    So, as nice as it would be, probably not. I'm sure someone can drash out a better answer than this (as could I if my fingers were more active!!).
    Anyone??
    Matt
  6. Desmo
    Desmo
    Jan 4, 2001
    14,296
    Braintree, Essex.
    +6,033
    Take a look at www.keene.co.uk
    Under the Products/Conversion/Other AV Converters section.
    PC - TV kit @ £99.99
