MacBook/Sky Q hub connection
Discussion in 'Networking & NAS' started by jonnyMercUK, Jul 18, 2018.
Tags:
  1. jonnyMercUK
    jonnyMercUK
    Apr 22, 2014
    365
    28
    +35
    Hi all,
    I have a MacBook Pro as a works laptop, when in the office i'm connected through ethernet and everything is fine. When i'm at home it simply won't connect to my Sky Q hub unless I restart. I can see the router name and I've tried turning WIFI on and off but it just won't connect.
    Does anyone have any suggestions?
  2. jonnyMercUK
    jonnyMercUK
    Apr 22, 2014
    365
    28
    +35
  3. mickevh
    mickevh
    Apr 30, 2007
    7,258
    West London
    +1,755
    The Wi-Fi and ethernet connections on a laptop are separate unrelated so there's no read across that because one works the other ought to.
    Does Wi-Fi connection work anywhere else?
    When you say "won't connect to my Sky Q hub unless I restart," do you mean restart the Mac, your router or something else?
    Are there any other symptoms apart from "won't connect" - like any error messages?
    Have you asked for any assistance from your company's IT Support?
