Macbook pro 2017 water damage
pricem321
Hi all, My son has spill water on his 2017 macbook pro, He shut it down straight away and turn it upside down for the last two days, He switched it on before and it wont switch on. I've taken the back off and I cant see any water anywere. Cant seem to see any videos on how to strip it down to check the circuit boards. Can anyone help me please. Thanks
DavidG1
Just do a search on YouTube for your model of macbook and disassembly. However for the high cost of the macbook you might be better taking it to a local workshop (not an Apple store) with experience of liquid damage. Also the liquid can cause corrosion of the tracks and components, the keyboard and power switch may have water (these are non-repairable) so the chances of someone with no experience successfully fixing it are small. Additionally you risk causing further damage if you don‘t know what you are doing.
