MAC OSX upgrade from 10.5.8
Discussion in 'Apple Forum' started by leaky5, Jul 27, 2012.
  1. leaky5
    leaky5
    Jan 3, 2003
    942
    43
    BasVegas
    +100
    I am a bit behind here !!! I was thinking of upgrading to 10.8, but I have to be on 10.6.6 first I think.
    Can't seem to find 10.6 on the Apple web site any more, does anyone know where I can still get it from ?
    I have seen trial versions of 10.6, is it possible to install this and then buy 10.8 ?
    IMac is a 2.66 Intel Core 2 Duo with 2GB of DDR3 memory.
  2. dante01
    dante01
    Mar 5, 2009
    46,616
    +11,232
    Here are the general requirements for Mountain Lion:
    OS X v10.6.8 or later
    2GB of memory
    8GB of available space
    Some features require an Apple ID
    and here are the supported models:
    iMac (Mid 2007 or newer)
    MacBook (Late 2008 Aluminium, or Early 2009 or newer)
    MacBook Pro (Mid/Late 2007 or newer)
    Xserve (Early 2009)
    MacBook Air (Late 2008 or newer)
    Mac mini (Early 2009 or newer)
    Mac Pro (Early 2008 or newer)
  3. leaky5
    leaky5
    Jan 3, 2003
    942
    43
    BasVegas
    +100
    Thanks, that all looks ok for spec, just need to find where to get 10.6.8 from.
  4. dante01
    dante01
    Mar 5, 2009
    46,616
    +11,232
    You first need a copy of OS X 10.6 Snow Leopard. You then need to update it to version 10.6.8:
    Mac OS X 10.6.8 Update Combo v1.1
  5. dante01
    dante01
    Mar 5, 2009
    46,616
    +11,232
  6. leaky5
    leaky5
    Jan 3, 2003
    942
    43
    BasVegas
    +100
    Dante01.
    I know this, but I am having trouble finding a copy of 10.6, all links to the Apple website pages for it are now dead.
  7. dante01
    dante01
    Mar 5, 2009
    46,616
    +11,232
    Read my last post.
  8. leaky5
    leaky5
    Jan 3, 2003
    942
    43
    BasVegas
    +100
    Sorry, thanks for that.
    Here's another thought. My son has now gone to 10.8 on his MB, am I allowed to use his old 10.6 disks on my Imac ?
  9. dante01
    dante01
    Mar 5, 2009
    46,616
    +11,232
    If his discs came with his Mac then it is doubtful that they will work with your iMac. The discs that come with a Mac are specific to that model and cannot be used on different models of Mac. If he purchase the 10.6 Operating System as a separate purchase then yes, you can use the disc to install the OS on your Mac.
  10. bryanchicken
    bryanchicken
    Aug 1, 2007
    1,301
    63
    +155
    If you don't mind a fresh install then can't you just purchase ML (on a mac with the app store), make a bootable usb stick with it and then install.
    You'll obviously need to backup all your apps and data as your hard drive will be wiped.
    That is what i did for my girlfriend who was on tiger and wanted to go to Lion. No Leopard or Snow Leopard necessary.
  11. nick1c
    nick1c
    Jan 3, 2009
    You are in exactly the same situation as me. 1st phone up the Apple store & buy snow leopard (os 10.6), this is £26 & will be posted. You can then buy Mountain Lion from the app store - there is no physical version.
