mac mini component
Discussion in 'Apple Forum' started by Bangalore, May 6, 2007.
  1. Bangalore
    Bangalore
    Feb 23, 2006
    241
    dewsbury
    +8
    hi guys (and girls),
    is it possible to output a component video signal via the dvi/vga socket on the mac mini?
    my plasma has a dvi input but it is currently been used for my dvd player using a component-dvi adapter. If the mac can output a component signal then the solution is simple, run the dvd player and mac through my amps switcher.
    my other option would be to run the mac mini as my dvd player and scrap the dvb player all together.
    what do you guys think?
    thanks
    sam.
  2. amardilo
    amardilo
    Mar 3, 2006
    5,457
    Milton Keynes
    +1,750
  3. bxd
    bxd
    Oct 17, 2001
    1,487
    Southampton
    +134
    If you look at the other thread on this subject, the answer is probably no.
    brian
