Mac mini and plasma TH-42PD25
Discussion in 'Plasma TVs Forum' started by macbandit, Jan 16, 2005.
  1. macbandit
    macbandit
    I have a 42" Panasonic Plasma TH-42PD25. I just bought a mac mini (http://www.apple.com/macmini) and want to plug it into my plasma and use it as a monitor. I am new to all this AV stuff but I know my Macs. The mac has DVI out. My plasma doesn't have DVI in but it has HDMI. I saw that there are converter cables available. How is the quality? It is better/cheaper to buy a hdmi to dvi adapter and just use a DVI cable or to use an adapter cable instead? I need about 25ft in length. Or is there another way? I can use S-video but the quality is poor. There is also a VGA in on the front but I want a rear connection to hide tha cables. I'm also curious what the resolutions will be and will it fill the whole screen?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    get a DVi> HDMI lead Better Cables make great cables and do DVi> HDMI that dont cost the earth (HDMI is DVi-D+Audio).....
  3. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +141
    Sorry for going :offtopic: but I am intrigued... did you import a PD25 into the UK or are you based in the US?
    S.
  4. macbandit
    macbandit
    I'm in the US. Paid $2700 for it.
  5. Rambles
    Rambles
    Jul 14, 2004
    8,131
    UK
    +1,105
    :eek:
  6. adrianl
    adrianl
    I know you wanted to hide the cables but I plug my Mac powerbook into Viera using the vga connection under front flap - the Mac (in that wonderfully mac-like way) automatically selects correct resolution. Excellent results using dvi-vga adapter provided with the powerbook.
  7. macbandit
    macbandit
    Too much or great deal?
  8. macbandit
    macbandit
    I do the same thing with my 12" powerbook. If there was a VGA connector on the back the problem would be solved. I just hope that the DVI connection does the same by autoselecting the resolutions and looks as clear.
  9. Rambles
    Rambles
    Jul 14, 2004
    8,131
    UK
    +1,105
    £1500 sounds really loads of money, I hope you are enjoying it - it cost me a third of that to build my Media Center 2005 PC, but....
  10. John
    John
    Dec 13, 2002
    11,266
    +2,881
    £1500 for his plasma :laugh:
  11. Rambles
    Rambles
    Jul 14, 2004
    8,131
    UK
    +1,105
    :blush: :oops:
  12. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +141
    That's alsohigh res and complete with HDMI socket... sounds like a bargain to me ;) :devil:
    Thanks for the info macbandit :) hope you get your Minimac sorted soon, sounds great actually, shame you can't stick a tuner in it and use it as a media centre of sorts.
    S.
  13. macbandit
    macbandit
    I thought about going this route down the road. http://www.elgato.com/index.php?file=products_eyetv500
  14. marc_hkg
    marc_hkg
    Back to original question: I have no answer but am planning to do the same with a Philips PF9966-42
    My Philips panel came with a DVI to HDMI cable included. In my ignorance, I attempted to hook this up to the analog VGA port on my Dell laptop using a VGA to DVI adaptor - that didn't work of course (now I get it - then I didn't).
    However, the Mac Mini should have digital output in the DVI out so theoretically it should work with the PF9966 plasma.
    Has anyone succesfully hooked up his Mac Mini to a plasma?
    Rgds,
    Marc
