MA silver series - S1 or SFX ?
Discussion in 'Home Cinema Speakers' started by petarst, Sep 16, 2005.
  1. petarst
    petarst
    Finally i have assembled my home theater system with MA sliver serise of speakers ( S8, SLCR, S1).
    Now some friends told me to put instead of S1 SFX speakers.
    They think that i will get better movie effect with it.
    My question is can I keep S1 in my configuration system or i must buy SFX speakers?
    Also can i leave S1 for 7.1 configuration of speakers?
    And last one, is that so necessary to buy that SFX speakers to replace S1 on REAR position?
  2. sonofmoth
    sonofmoth
    Nov 30, 2002
    384
    I'd say no, but if you're going 7.1 get the SFX for the side walls.
  3. petarst
    petarst
    Thx for replay to me,
    Can I go with BFX - brozne series of speakers instead of SFX?
    Are the SFX are good for dvd-a and sacd or I must use S1 for it ?
  4. sonofmoth
    sonofmoth
    Nov 30, 2002
    384
    I'd be inclined to go with the silvers as they are matched.
    My gut feeling would be to keep with the S1's for DVD-A or SACD. Better still get another pair of S8's :)
  5. sonofmoth
    sonofmoth
    Nov 30, 2002
    384
