MA GR10 Tweeter
Canucklehead
Hi everyone,
The tweeter on my GR10s just blew after they were knocked off thier stands -- any ideas about how expensive a repair this is likely to be ?
I got the speakers 2nd hand; so no warranty AFAIK. Do things like this pop up on the forums/fleabay, or is my best bet just to call up MA for a replacement driver ?
Thanks !!
Crustyloafer
I would speak to you local dealer who will be able to order one for you and fir it too. I would expect the cost to be around £40-50.
Knyght_byte
aye, get a dealer to do it, saves a lot of hassle and potential problems..
i very much doubt you'll see GR10's on ebay for less than £100.......
and such lovely speakers, i just rehooked mine back up at last in my bedroom to my A5 and 3910.....awwwwww......Fatboy Slim never sounded so good!
Canucklehead
Well,
Ended up calling MA directly; (who were extremely helpful BTW) who figured it said it was extremely easy to swap around the tweeter. Two days later it was delivered and I installed it last night in about 5 minutes. They even threw in an extra screen guard for my other tweeter so hopefully I can prevent this happening again !
Not cheap at 105+VAT; but quick, easy and worth it now that my babies are up and running again !!
