MA Centre?
Discussion in 'Home Cinema Speakers' started by docb, Oct 19, 2005.
  1. docb
    docb
    Nov 22, 2004
    253
    Hello All
    I have recently upgraded to GR10's for my front two, and I am now looking for a matching centre.
    Would a bronze/Silver centre be tonally matched to the GR's?
    And if they are then what would I be getting for the extra expense if i bought the gold centre?
    Thanks in advance
    Doc
  2. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    um, i would imagine at that price level you are better off using the GR centre to keep it tonally matched completely......the silver centre is fantastically good (i own one..lol) but tbh the Gold is even better and you might find the front of your HT sounds a bit odd.....mebbe im wrong, get a demo, but i know i'd rather match it than mismatch it...
    the bronze centre most definitely would not be matched, the bronze speakers have nowhere near the treble control or definition that the Golds do, and the midrange isnt so hot either....also the Gold centre goes as low as the GR2s i think so will work nicely for crossover purposes....
  3. kr1s
    kr1s
    Apr 5, 2005
    11
    3
    Las Vegas
    I havent heard the current RS series, but listening to both silver S LCR and Gold LCR back to back the Gold was miles ahead of the Silver IMO.
  4. docb
    docb
    Nov 22, 2004
    253
    kr1s and knyghtbyte
    Thanks for your replies, looks like its the gold
    Thanks again
    doc
