MA Bronze B4 or B6
Discussion in 'Home Cinema Speakers' started by rhawk, Mar 21, 2005.
  1. rhawk
    rhawk
    I've more or less finished my dedicated home cinema room. I have a 37" 4:3
    Mitsubishi TV, a Marantz SR7500 amp and am going for a Monitor Audio Bronze speaker package. My room is very well insulated and measures 17x10 feet. Does anyone think if it would be wiser to spend the extra £135 and go for the B6 floorstanders instead of the B4's. Or should the B4's be more than ample for my set up? Thanks :)
