Question MA Bronze 5.1 + in wall rears + ceilings
Discussion in 'Home Cinema Buying & Building' started by jws, Jul 10, 2017.
  1. jws
    jws
    Jul 19, 2009
    22
    3
    +3
    I'm wondering whether the MA Bronze 5.1 package + a pair of WT165s or similar in walls would work ok together? Would put the BXFX as surrounds and then in walls at the back behind the sofa to create a little more space in the room and not need the rear seats as far forward.
    Room is 2.6m wide x 5m long - very early planning stages but will be sound treated and a dedicated cinema room. Also looking at going for four in ceiling MA CT165s for Atmos to get the full 11.1 setup.
    Looking at using a Marantz MR7011 + extra amp for the ceilings to run the lot as the package deal for the Bronze 5.1 + MR7011 via Peter Tyson looks very good.
    Thanks,
    John
