m5ds, m77ds, mordantshort 903s
Discussion in 'Home Cinema Speakers' started by craynerd, Oct 23, 2005.
  1. craynerd
    craynerd
    Aug 10, 2005
    331
    I have norrowed it down to these three for my rears. I can get them all second hand for less than £100. Whats your vote ?? (any other recomendations for less £200)
    Chris
  2. Mentally
    Mentally
    What amp?
    What music do you listen to?
  3. craynerd
    craynerd
    Aug 10, 2005
    331
    sorry never mentioned, amp is Denon 2106, but does the music matter since do u not just use rears for movies and 5.1 ? thought audio was stereo?!?!?!
    i listen to punk and rock but g/f who will be equally using the system listens to pop and cheese!!!! basically, it needs a wide range
  4. Mentally
    Mentally
    You should know that MS speakers have superb sound when playing classical. Other styles are problematic.
    I suggest you take your reciever and listen to the speakers before you buy them. If u can't do it, it's ok these are only the rear speakers, not that critical.
  5. thekingbeyond
    thekingbeyond
    May 24, 2004
    6,319
    oxfordshire
    +411
    m5ds, m77ds, mordant short 903s, my choice would be the 903s they are of a better build quality and they beat the m5ds`s and m77ds`s for movies and sacd or dvd-a music also sound better.Imo i think they are better looking than the mission speakers.
    I am not biased as I have just got rid of some m77ds`s and still own some m5ds`s and 903s`s although i dont use them anymore
  6. pragmatic
    pragmatic
    Nov 9, 2004
    12,156
    +1,647
    I have m7ds and it sounds great, there are no integration problems with my B&W fronts plus i'd say its equaly as good at music as it is in movies, and altohugh rears don't produce much bass i'd say with a well integrated sub they sound fine and certainly give the impression that the bass is coming from them at times.
    You should demo if you can, as its often all down to personal preferance and try and demo run in speaker if you can as the new MS may not sound like what they would in time (i.e. they may sound a little harse at first but this usualy subsites).
  7. Astaroth
    Astaroth
    Jun 22, 2004
    3,708
    London
    +898
    I also have the M7ds (not sure if you ment these of the 77ds) and they are certainly reasonable for the price. The M5ds and 77ds were both good speakers (and traditionally considered higher spec than M7) but did have a slightly softer sound.
  8. binbag
    binbag
    Jun 16, 2004
    1,717
    North Kent Coast, SE UK
    +81
    I got a pair of Wharfdale DFS-18 for £50 from HiFiBitz earlier this year and I rate them.
    That offer is gone but these are in your price range:
    http://www.hifibitz.co.uk/product.asp?id=4027
    Integration isn't as important with rears as it is with fronts & centres btw.
