M400 Problems...
Discussion in 'Projectors, Screens & Video Processors' started by T3hSquall, Aug 28, 2005.
  1. T3hSquall
    T3hSquall
    I need help with my IBM M400. It just came out of waranty like 2 weeks ago, and then the thing just kinda died on me. I was pullin the power cord outta the back and as i turned it sideways it just kinda popped a few times and killed itself. The kind people at IBM don't seem to wanna help me out, so I was hoping someone here could help me to fix the problem. Also, if anyone's had a similar problem let me know. Thnx in advance
    Oh, and I know what ur first thoughts may be... its the bulb, but i figured if that was the case the thing would atleast turn on...
  2. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,140
    Surrey. UK.
    +1,953
    Could be the fuse in the plug, or an internal ceramic/glass fuse maybe.
    Does the power lead work with anything else? Try it on something to see if the fuse is still intact unless you have a means of testing it yourself. If it's a kettle lead, don't try it on that as it will probably blow the fuse if it's still OK. :)
    Gary.
  3. T3hSquall
    T3hSquall
    how would i check the ceramic fuse if that was it. and thanks for the help. oh another thing, does the bulb compleate a circuit in projectors, if so then maybes is the bulb, and pwr isnt getting past the bulb? i dunno much about these things obviously... but ud think if they're gonna be so expensive they could be easier to operate.... (oh and it is a kettle, the one with the round prongs)
  4. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,140
    Surrey. UK.
    +1,953
    The lamp is an independant part usually, and the pj will tell you if the lamp has failed (LEDs flashing or lit to show a failure). The fuses are inside and you'll have to take it apart to get to them. Not sure if that's the sort if thing you'd do yourself or take it to a shop though.
    Can you check the fuse in the plug?
    Gary.
  5. T3hSquall
    T3hSquall
    ive never actually done that before...
  6. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,140
    Surrey. UK.
    +1,953
    Never checked a fuse in a plug or taken a pj apart?
    Gary.
