M35's & M3c2 or save for B&W 602.5 & LCR60
Discussion in 'Home Cinema Speakers' started by pgre, Jun 29, 2004.
  1. pgre
    pgre
    Dec 5, 2003
    88
    Basingstoke
    Go on your views..
    I listend to the M34's today and the 602.5's (with the centres also), but wanted your views. They didn't have the M35;s in stock and I can only find limited (reviews) info on line about them. The threads here suggest the M35 is a much better choice that the M34's ??
    The 602's were v nice.. less Bass that the M34's but more controled I thought... but more expensive.. the normal dilema I guess.
    Feel free to add your thoughts..
  2. rozzar
    rozzar
    Sep 29, 2002
    1,056
    41
    Braintree
    +23
    get a listen to the '35s. they are considerably better than the 34s. i think its the dedicated midrange driver that does the business, but they really do sound very good and fantastic material value for £400
    haven't heard any B&Ws for ages so would be unfair of me to comment.
  3. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Or the cheaper and maybe better than the M34, the model M33...
