M1+ remote and telewest
Discussion in 'Cable TV & Virgin Media TV' started by MonkeyNutz, Jun 4, 2005.
  1. MonkeyNutz
    MonkeyNutz
    Mar 19, 2005
    163
    +4
    Hi, Ive just bought a cambridge audio M1+ remote and I`m having trouble getting it to work with my telewest box.
    I read through posts on this forum and found that my telewest box uses a different standard ir to most other things.
    I found the redeye site and this seems to be the solution.
    anybody use this combination, M1+ / redeye / telewest box? does it work well?
    Or am I better off taking the M1+ back and getting a different learning remote, if so any suggestions what to go for?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    you'll need a red eye with almost any learning remote so may as well get one now
  3. MonkeyNutz
    MonkeyNutz
    Mar 19, 2005
    163
    +4
    Thanks, I`ll get one ordered tommorrow.
    Just out of curiosity will telewest exchange the box for another with proper ir if I ask them? Seems unlikely but has anybody tried?
    thanks
  4. mattross
    mattross
    Oct 23, 2004
    265
    +7
    They would never replace it if nothing's wrong with it. I'm on ntl: and I know through experience.
