M1-DA Two into One
Discussion in 'Projectors, Screens & Video Processors' started by JEDIBLADE, Aug 4, 2005.
  1. JEDIBLADE
    JEDIBLADE
    Sep 24, 2002
    1,614
    Sheffield
    +140
    I have an InFocus 4805 with an M1-DA conector on the rear. I have a Denon 1910 that outputs DVI and I also have a PC that output's VGA. I have the supplied Infocus adaptor that changes the VGA into M1-DA and a Lindy Adaptor that changes DVI into M1-DA. The problem is I only have one M1-DA connection ? Does anyone know if a company makes a two into one M1-DA switcher ? At the moment I have to change the lead when I want a different source :confused:
  2. markwww673
    markwww673
    Oct 31, 2003
    2,978
    103
    Midlands
    +321
