M&K Wall Facing
Discussion in 'Subwoofers' started by scarty16, Aug 27, 2005.
  1. scarty16
    scarty16
    Jul 1, 2003
    1,354
    +294
    I have just bought a M&K 850 and the dealer has told me to face it towards the wall, as M&K design them to do this, is this correct, and if so how far away should it be?
    It is in a corner at the moment and faces one of the 2 walls at 4 inches.
    Simon
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,213
    The Borders
    +2,931
  3. kbfern
    kbfern
    Aug 17, 2002
    17,738
    Wolverhampton
    +5,934
    I don't know what M&K recomend I am sure IanJ will be along soon with some advice as he has M&K speakers and I am sure he will know the answer.But whatever the recomendation is you should use your ears(and spl meter),try both ways and see what sounds better in your room.
    Placement and positioning of most subs is trial and error and small changes in placement can make huge differences.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,213
    The Borders
    +2,931
    Hello Keith
    If you read the question it asked did M&K recommend you fire the 850 sub 'at' your wall - I would have thought if that statement was true then the user manual would have confirmed it or not.
    IanJ may have M&K loudspeakers though that does not necessarily mean Ian has any experience of the V-850 - or are all M&K speakers created equal? I hope not!!!
    As you say an SPL meter, a test disc and lots of time trying out various positions will deliver the optimum result in any room - though I very much doubt the 'fire it at the wall' position will be the best option.
    Best regards
    Joe
  5. recruit
    recruit
    I know alot of people do use this method and find it works very well, saying that though i have always had my MX350 driver faceing towards the listening position with excellent results too.
    Every room is different so therefore i would experiment and try to find what gives the best results in you're room and when happy leave it there :thumbsup:
    Edit : BTW i did have an M&K V851 sub and in my room found that it worked well with the driver again faceing the listening position, excellent sub aswell...
  6. dts_boy
    dts_boy
    Nov 26, 2001
    2,587
    Manchester suburbs...
    +178
    i think the MX series of m&k subs should be setup facing a wall. They are vented in this fashion and irc work best like this. I had a vx100 which was a cracking little sub but then i moved house and it got lost in the much larger room :(
  7. recruit
    recruit
    Yep, i have spoke to a few people and they have told me the same....
  8. scarty16
    scarty16
    Jul 1, 2003
    1,354
    +294
    thks everyone, I think I will start the experiments tonight, in the words of john Hooker, boom boom boom boom
  9. KHCC
    KHCC
    Aug 10, 2004
    256
    Kent
    +10
    Mornin'
    The MX700 and MX5100 (new) has been designed specifically with their 'Backfire Technology' as it increases the pressure on the cone when the drivers are against the wall. From now, every new M&K sub will be designed this way so I've been told!!!
    I wouldn't take the dealers word as gosple, although not untrue, but, as previously stated in this thread, you should experiment with placement and orientation as every room is different.
    Regards
