M&k Vx100 Sub
Discussion in 'Subwoofers' started by DodgeTheViper, Apr 2, 2002.
  1. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    19,487
    Inbetween Upgrades !
    +7,767
    Hi All,
    I am currently experimenting with set up and positioning of the VX100. I am using the spiked feet, and my carpet is quite thick. Because of the carpet, the base of the sub is only clearing it by 1/4" or so. I think it needs to be raised a bit higher to allow the driver to breathe and release some of the good stuff !!
    Trouble is, i dont know how to raise it. The spikes are at maximum length.
    Does anybody know how i can raise it a little further from the carpet?
    Cheers for the help.
    Kev
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    You could try putting it on a slab of stone or MDF to raise it.
