M&K Upgrade advice please
Discussion in 'Home Cinema Speakers' started by hektic, Sep 21, 2004.
  1. hektic
    hektic
    Oct 17, 2001
    114
    Midlands
    +8
    I hoping someone can point me in the right direction for an upgrade.
    My current setup is M&K 1250 sub with M&K K4 tripoles for SR,SL and 2 SB's.
    I have AE Evo III fronts and center. I don't really listen to music on my kit and I don't rate the center speaker so I think these are the three things I'd like to replace. I'd like to stick with M&K but I'm not sure what will suit my existing M&K setup best. My budget is about £1500.
  2. recruit
    recruit
    Hi hektic,
    I have the M&K 851 LCR and i think they are a superb, i'm sure they would sound really good with your existing M&K's and they are about £1500 for the 3 of them, I use the LDM Stands though and that would cost another £450 on top, but i'm sure you could use other stands to go with them ;)
    John :)
  3. hektic
    hektic
    Oct 17, 2001
    114
    Midlands
    +8
    Thx Recruit!
    I'll demo what you've sugested :smoke:
    I wonder if my 3802 will cope with 7 speakers at 4ohms?!?
    btw: You have some setup there matey ! :cool:
    How do you rate the Z9?
  4. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,080
    notts.
    +63
    Where abouts are you in the midlands as your welcome to listen to my m&k 850s paired with an svs sub.
    Cheers Gonzo. :)
  5. Smurfin
    Smurfin
    Aug 13, 2002
    21,421
    +4,349
    Not very well, especially if you listen at high volumes. The 850s/851s are notorious for being "edgey", and partnered with unsuitable amplification (which the 3802 is on a busy soundtrack), will make that edginess even more pronounced. IMHO of course, as although I've heard the 850s several times, I've never heard them with the 3802, but I understand that the power output of the 3802 drops severely with all channels driven (don't believe the paper spec that Denon claims, basically).
    If you want to go M&K then look at the K7s, or much better - hunt down a set of S85s (keep an eye on the classifieds), which are excellent speakers. Still might be difficult for your 3802 to drive though...
  6. recruit
    recruit
    Hi Hektic,
    I would agree with smurfin in that your 3802 might struggle to power the M&K's, they do like alot of power to drive them.
    My Z9 drives them quite comfortably as there is alot of power in the Yamaha.
    Also the K5's and K7's are excellent speakers for home cinema maybe give them a try.
    John :)
  7. hektic
    hektic
    Oct 17, 2001
    114
    Midlands
    +8
    Thx guys,
    I think I'll have a look around at power amps before buying the speakers.
    If I do this I can save up for a processor in the future instead of buying another intergrated.
    Thanks for your advice guys.
  8. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    Have been using a 3802 to run my 3 x k17s pair of k4s and 1 x k15 rear centre for over 2 years without any problems at all listerning levels, this is not to say that a better receiver or amp could do them more justice
  9. Lennyz
    Lennyz
    Jul 27, 2002
    339
    Cheshire
    +13
    I have been using my K series setup (3 x K7 and 2 x K4) for 2 years now with an Onkyo 575x. I have wondered how they would sound with better amplification but I am still really happy with the sound they produce.
    Maybe when funds allow I will upgrade the amp but it has never had any problems driving the speakers despite the 4ohm rating of the k's.
    K series are fantastic sound for the size if a littler pricey ( I imported mine so I could save cash however ) give them a listen with differeent amps and see what you think.
    Lennyz
  10. Philly112
    Philly112
    Oct 17, 2003
    4,310
    Frodsham
    +1,657
    I notice that a set of M and K S85 speakers have just come up for sale on the classifieds. ('cuscus'). I had a full set of these before 'upgrading' to the S125's, and, quite frankly, there is very liitle difference. The S85's are class!
