m+k ss150thx rears good match for 850s?
Discussion in 'Home Cinema Speakers' started by benny, Jun 4, 2005.
  1. benny
    benny
    Jun 4, 2005
    2,890
    Hartlepool
    +977
    was just wondering if anyone can reccomend a good match for the m+k 850s for the fronts,what to get for rears, also any other speakers recomended instead of miller and kreisel.
  2. recruit
    recruit
    Hi benny,
    Welcome to the Forum, Yes the SS-150 THX speakers would be a good match for the 850's, you may also want to consider the M&K Column Surround speakers which are also very good speakers and work really well, there is also the option of the cheaper K4 surrounds which are very good and quite a few forum members use these. I have not heard any other surround speakers that work as good as the M&K's.
    John
  3. benny
    benny
    Jun 4, 2005
    2,890
    Hartlepool
    +977
    Thanks recruit, i appreciate your response.
    cheers ben.
  4. Shaka
    Shaka
    Jul 26, 2004
    724
    Glasgow
    +39
    A few weeks ago I auditioned the S-150 package using SS-150 for surrounds, they sounded fantastic. I recently also auditioned the 850's using K4 surrounds. The K4's were OK, but I found them a bit distracting. I prefer the SS-150's & agree with John, the SS-150's would go well with the 850's.
    As John says, you should also consider the column surrounds. I've had my CS-29's for a few days now and think they're fantastic. They create an extremely effective surround field around the listening position and the F/X's just seem to appear from everywhere. You can't tell if they're coming directly from the speakers, just how it should be.
  5. benny
    benny
    Jun 4, 2005
    2,890
    Hartlepool
    +977
    Thanks shaka
  6. Dellboy
    Dellboy
    Apr 24, 2002
    596
    43
    The Cotswolds
    +125
    I have the 850 for the left centre and right and I also have the 150's for the rears. Great choice and work perfectly well together. My 150s are wall mounted at head height.
    The mks also like good speaker cables. Kimbers are recommended.
