M & K Pro. CR1403 impedance
Discussion in 'Home Cinema Speakers' started by jakebev, Sep 21, 2005.
  1. jakebev
    jakebev
    Aug 16, 2005
    466
    43
    London
    +130
    Just inherited a pair of M & K speakers (well, loaned). Now the instructions say that the impedance of the speakers is 8ohm, but the speakers themselves say nothing. I thought the speakers had less of a tolerence, and before hooking them up and exloding them, I thought I'd better check to see if anyone can shed some light on the matter.
    The speakers are being hooked up to a Yamaha RX-V4600, and this does 8ohm.
    Any thoughts?
  2. jakebev
    jakebev
    Aug 16, 2005
    466
    43
    London
    +130
    Also, does it matter that the speakers are American?
  3. 30CenturyMan
    30CenturyMan
    Dec 3, 2004
    927
    46
    +116
    M&K are *usually* 4 Ohm.
    American speakers work just as well anywhere else in the world, as they do in the States. :)
  4. ufitsy
    ufitsy
    Aug 18, 2004
    3,237
    103
    Midlands
    +341
    It is true that a lot of M&K speakers are 4ohm, these are 8ohm surround speakers & as such should work fine as rears, will not give much below 100hz though.
  5. jakebev
    jakebev
    Aug 16, 2005
    466
    43
    London
    +130
    thanks for the help :smashin:
    will try them out and let you know if they go pop! :eek:
