M&K or Genies or ??? for AX5i
Discussion in 'Home Cinema Speakers' started by uncleg, Nov 18, 2004.
  1. uncleg
    uncleg
    Mar 22, 2004
    25
    3
    Northfleet Kent
    I am a newbie to the home cinema world but I have been reading this site for some time.
    I have decided to enter the field and I am somewhat confused. :confused:
    I am planning to buy the Pioneer 868 and the AX5i, but I am not sure on the speaker/sub set up!!
    The system will be 90% movies and from reading this forum M&K seem to be favourite.
    I went to Sevenoakes and all the guy kept ranging on about was the Xenon range. When I asked about the k series (recomemmeded by a majority on this site) he dismissed them and went on about the Xenon range.
    After annoying me I left!!
    But now I see that the MS Genies are also a good buy. Hence the confusion.
    So help is needed PLEASE!! - movies is priority and suitable ones for the amp and dvd I have chosen.
    Room is small so columns etc are out as are wall brackets - will have to be stands. :lease:
    Price can vary if the produce is the best!!
  2. recruit
    recruit
    Hi Uncleg,
    The Xenon range are quite expensive but are very good but so are the K series of speakers.
    The Genies have had rave reviews and i think Tons_of_Fun would be the best person to comment on that range, also they are quite alot less than the M&K's but it is all down to preference and your wallet.
    Can you demo both the K & Xenon range of speakers as i would suggest doing that atleast to see which you prefer.
    Personally i would say the M&K's would be better than the Genies but by how much i would not know?
    John
  3. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,963
    2
    +3,331
    I would hope the M&K packs are better than Genie as they cost quite a bit more! Genie is (IMHO ;)) a good sounding and pretty musical setup to boot. For about a grand for 7 channels it really is worth a listen but I would see it giving ground to the more expensive (and ugly :p) M&K's.
  4. recruit
    recruit
    Ugly Nah, Beauty is in the eye of the Beholder :D
    John :p
  5. Matthew J Taylo
    Matthew J Taylo
    Jan 3, 2003
    164
    19
    Adelaide
    Recruit,
    How do the tripole M&K's do for 5.1 music? do they enhance or confuse the sound?
    I'm looking at the K5's or the K15's, both come with the tripole K4's for my AX5i & 868avi setup.
    Matt
  6. recruit
    recruit
    Hi Matt,
    I have not heard the K4's but from peoples views on this forum they are very good, i myself have the CS29's which are columns and to me they sound excellent with both Movies and Music, i have had normal speakers as rears but i tend to prefer the sound with tripoles it gives a more ambient effect IMO which i like for 5.1 Music, with movies the tripoles excell :smashin:
    John
  7. Matthew J Taylo
    Matthew J Taylo
    Jan 3, 2003
    164
    19
    Adelaide
    thanks John,
    With traditional 5/6.1 set ups these days the rears are almost "sides", how do you position tripoles?
    Matt
  8. recruit
    recruit
    Matt my tripoles are positioned at the sides of my seating pos but i have 2 K15's at the rear and find this rearly works well, most of the time i do not use the 2 rear's and just have 5.1 rather than 7.1 running.
    John
  9. Matthew J Taylo
    Matthew J Taylo
    Jan 3, 2003
    164
    19
    Adelaide
    John,
    When you say at the sides, do you mean with the main speaker pointing towards the front, tilted @ 45 d or facing you?
    Apologies for this
    Matt
  10. recruit
    recruit
    Matt the column surrounds are slightly different to the K4's here is a link but when you can see them they are at the sides up against the wall fireing upwards and to the sides...
    www.mksound.com/surround_speakers.php
    John
  11. Matthew J Taylo
    Matthew J Taylo
    Jan 3, 2003
    164
    19
    Adelaide
    Many thanks John
    Matt :smashin:
