benzi
Established Member
Evening all,
Is anyone using the Dali Rubicon On Wall LCR?
I've got the M&K Sound MP950 in black satin but like the walnut veneer available with the Dali.
I've got some Oberon on walls which sound great but wondering whether the Rubicon would be an upgrade or more like a sideways step compared to the M&Ks.
Has anyone tried the Dali Rubicons on walls Vs M&Ks? Rubicon measures a bit wider and deeper in dimensions.
I'm using with Yamaha RXA3070 and Lyngdorf TDAi 3400...if that makes any difference..
Thanks in advance.
Benzi
Thanks in advance.
Benzi
