M&K Max output terminals
Discussion in 'Home Cinema Speakers' started by Jack the lad, Sep 15, 2005.
  1. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,033
    New Zealand was Nottingham
    +86
    Anyone used the Max output terminals on their M&K speakers?
    If so what did you think?
    Also what level did you then set your sub to 80hz, 100hz?
  2. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,033
    +86
    Anyone? :)
  3. 30CenturyMan
    30CenturyMan
    Dec 3, 2004
    760
    +47
    Yes, they sounded 'brighter' and the crossover should still be set to 80Hz. :)
  4. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,033
    +86
    Cheers mate :)
    Did you keep them like that or did you prefer the normal setting?
