M&K K4 and S85's
Discussion in 'Home Cinema Speakers' started by Jack the lad, Jun 26, 2004.
  1. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    New Zealand was Nottingham
    +86
    Are M&K K4's for side use any good for 7.1 when S85' are being used for L,C,R and rears?
    Or are there any other alternatives? :)
  2. CYRUStheVIRUS
    CYRUStheVIRUS
    Jan 25, 2003
    1,409
    41
    Berkshire
    +17
    Depends what you want to spend? M&k ss150 could be used and would suit look and tone of package, but are expensive.
  3. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    To be honest the £500 for the K4's is pushing my limit :)
    Just wondered if they would do the S85's justice. They wont be played at reference levels unless the missus and kids are out ;)
  4. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,092
    notts.
    +64
    Hi Ash
    The k-4s will be fine with the s85s as you know they intergrate well with my m&k 850s they are also rated at 200 watts max power same as the s85.
    Cheers Gonzo. :)
  5. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Hey up mate :hiya:
    Fancy doing a bit of setting up in a couple of weeks? :D
    I think Im gonna go for a Rocket sub unless my arm is twisted :rotfl:
  6. ddlooping
    ddlooping
    Oct 7, 2003
    1,446
    Essex
    +27
    HI all. :)
    Jack, I should soon be receiving a pair of S85 and a REL Q100e (hopefully at the beginning of the week).
    They will be used with a S85C, a pair of K4s (as rears), and a Denon AVC-A11SR and DVD3800.
    Not the same set-up as yours, but I will then be able to give you some feedback. ;)
  7. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    That would be good.
    I have heard Gonzo's setup and it sounded good. So I will be getting a pair of K4's for sides :)
