M & K - K Series
Discussion in 'Home Cinema Speakers' started by viewer, Dec 5, 2004.
  1. viewer
    viewer
    Sep 26, 2004
    91
    Anyone know where I can get M & K K series speakers. Looking at K7's and K4's
  2. recruit
    recruit
    Alot of Sevenoaks Sound & Vision Outlets will do the K series but it depends where you are located and if they are authorised dealer, the other option would be to contact Gecko which is the UK distributor..
    Here is there Tel N# 020 8603 0480 they should be able to tell you the nearest one :)
    John
  3. jasonx32
    jasonx32
    Oct 7, 2004
    279
    19
    yep, john's correct there. sevenoaks is your best bet.
    you can't go wrong with the k series. i'm running 3xk7's as fronts and 4xk4's as rears and they sound fantastic. make sure you've got a good powerful amp to drive them though! they may look small, but they really shine with some proper power behind them.
    jason
