M & K K-5
Discussion in 'Home Cinema Speakers' started by chris V, Dec 27, 2004.
  1. chris V
    chris V
    Dec 7, 2004
    27
    Am looking at buying a set of these (I like the small format of the speakers, don't want floorstanding speakers) to run with an Ax5 - anyone got any comments or advice please....
  2. recruit
    recruit
    Hi Chris,
    M&K speakers are renowned to be power hungry speakers and the AX5 should not have a problem driveing them, they give a very big sound from such small speakers which is ideal for most sized living rooms.
    They are a sound that not everyone likes though and a demo should definitly be on the cards before purchaseing as they are extremly detailed in there presentation so i would have a good long listen to see if it is what you like.
    I love the sound of M&K speakers and the K5's are definitly a good choice and also very wife/girlfriend friendly speakers due to there size.. :)
    John
  3. Tejstar
    Tejstar
    Dec 4, 2002
    22,519
    London
    +1,005
    I find M&K's a bit aesthetically challenging... :p
  4. recruit
    recruit
    You would... :D
  5. rags
    rags
    Apr 13, 2003
    4,087
    London
    +304
    Not a problem Tejstar - there is no reason to feel ashamed about it. See those binding posts at the back thats where the speakers wires should be connected. The other side of the speaker cable goes into something we AV folk call an "amplifier". If you need to know more detail feel free to ask !
    :p :D
  6. Tejstar
    Tejstar
    Dec 4, 2002
    22,519
    London
    +1,005
    Great stuff :laugh:
  7. chris V
    chris V
    Dec 7, 2004
    27
    ah. Thanks for that guys, but I was hoping that someone might suggest some alternatives....
    Chris V.
  8. chris V
    chris V
    Dec 7, 2004
    27
    Sorry - I should have said at the outset. These will be used for Surround system - NOT for music.
    Chris V.
  9. recruit
    recruit
    Chris - On the origianal post you asked preference to the M&K K5's so views were expressed but if you are looking for alternatives you should of put that aswell.
    Anyway as for alternatives you could look at the MS-Genies or the Kef Eggs but they are not in the same class as the the M&K's, also you could look at the ProAc Hexa speaker package which is a superb speaker set but is more orientated to Multichannel Music which they excel at and are a bit more expensive aswell!
    John
  10. Tejstar
    Tejstar
    Dec 4, 2002
    22,519
    London
    +1,005
    How about Castle Compact CC3's which retail for around £1k?
    Better than the Kef eggs and Genies but not as good as the Pro Ac Hexa's.
    Btw does anyone know the website for Castle?
  11. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,078
    notts.
    +63
  12. chubbyandy
    chubbyandy
    Hi there,
    How do the Castle's compare to the MA B2 or BE AV or the EPOS ELS 3 5.1
    I have heard the MA's they are quite good. Not heard the Epos or the Castles yet. If I were to go with the Castles, then it would have to be a blind buy as the dealer does not have a set for demo.
    I do not like bright or thin sounding speakers. Full-bodied, smooth with lots of detail for me. Not a big bass freak, just tuneful and tight, not necessarily loads of it. Set for my 16 X 11 X 9 bedroom.
    Thanks.
  13. chubbyandy
    chubbyandy
    oops..B4, I mean.
  14. hutchys
    hutchys
    Feb 4, 2002
    135
    16
    Sorry to intrude but can anyone tell me if a Denon 2802 will be ok to drive the K5's for surround and maybe a K7 for centre?
    Jim
  15. hutchys
    hutchys
    Feb 4, 2002
    135
    16
    Does anyone know if my 2802 can drive the K5's please?
    Jim
  16. recruit
    recruit
    Jim - The 2802 may drive the k5's but not as well as a more powerfull amp will, the sound might harden up quite alot at higher volumes and become harsher as they are 4ohm speakers. If you could get a listen to the M&K / Denon together you can hear for yourself.
    John
  17. hutchys
    hutchys
    Feb 4, 2002
    135
    16
    Thanks Recruit,
    So in your opinion what is the minimum amp that should be used to drive the K5's? Bearing in mind I am not looking to spend a great deal on another amp if possible or could you recommend some other speakers to trial that I could use with the amp I have at present just speakers as I have have a sub.
    jim
  18. recruit
    recruit
    Jim - I would of thought something like the 3803 / 3805 amp up would really be the minumum to drive the K5's well or any other good midrange amp should be ok.
    Other options with you're amp would be the Kef Egg speakers or the new MS Genies & another 1 to consider would be the Castle compact speakers.
    John
  19. Tejstar
    Tejstar
    Dec 4, 2002
    22,519
    London
    +1,005
    Cheers Gonzo, spent ages trawling around google trying to find that :)
