happychappy
Established Member
M&K flush mount speaker bracket buying information
Hi folks
Not sure if this is the right room to post this or if it should be in D.I.Y? If so can a Mod move it please
I have, after many hours searching, found a supplier for the flush mount type wall brackets that are used with the K series 7,5,4 speakers and most probably many more.
The company is wirecare.com in NJ USA
WireCare.com | Your Local Cable Management Superstore!
The product is made by L&M Metal Products, the code is - FM-001B it's essential to get this right!
Here is a link to the L&M advert:-
http://landmmetal.com/images/lmmetal.pdf
I have just ordered from Wireworld, the cost was $31.75 for five pairs posted to the UK
Good luck, hope this helps other enthusiasts out.
Hi folks
