M&K column surround query
Discussion in 'Home Cinema Speakers' started by robfitzp, Dec 25, 2004.
  1. robfitzp
    robfitzp
    Dec 12, 2002
    1,162
    38
    Bristol
    +20
    Thinking about getting these to replace mission DS bipoles.
    Any problems using 4 of them for L/R surround and L/R rear?
    Are they fussy about placement for L/R surround, i.e. do they need to be parallel to the listening position or can they be slightly forward / behind it?
    Any noticable difference in performance of CS22, 29 or 35?
    Will be using with Nautilus 804/HTM1 and Pioneer AX10. Input from anyone using these gratefully received.
    Rob
  2. recruit
    recruit
    Hello Rob & Merry Xmas,
    I have been useing the M&K Column surrounds for sometime now and they are the best surround speakers i have heard.... :)
    Mine are placed at the sides of the seating pos and work superbly in 5.1 format and sometimes i listen in 7.1 with 2 K15's behind me, IMO if you were to use 2 more for the rears i don't see that as a problem and would probably work very well as they are so easy to install and give a great dispersion of sound that is hard to locate the source.
    They are expensive speakers but worth every penny and even if i upgrade my fronts i will always hang on to the Columns.
    BTW mine are the C29's and use the same drive units as the other 2, i dont think that there is any difference between the 3 as they all use the same drive units apart from there height.
    Thoroughly Recommend them :smashin:
    John
  3. robfitzp
    robfitzp
    Dec 12, 2002
    1,162
    38
    Bristol
    +20
    Hi John
    Thanks for your reply and Merry Christmas to you too (and to all forum members...)
    Good to hear such a glowing endorsement - if they are not going to result in upgradeitis then they are worth the cost :thumbsup:
    My wife particularly likes the idea of speakers being hidden behind the sofa...
    Did you get yours in the UK or import like Rags?
    Rob
  4. recruit
    recruit
    Yes i bought mine here in the UK but got a nice Discount so it was worthwhile :) I know Rags imports his which can save a hell of alot of money and can definitly be wothwhile checking out especially if you are looking to get 2 pairs.
    Also Rags runs his with the Nautilus Range of speakers at the front which is exactly the same as what you have 804's & HTM1 and the M&K's Columns work seamlessly with them.
    John
  5. rags
    rags
    Apr 13, 2003
    4,089
    London
    +323
    M&K gear is worth importing due to the favourable exchange rate atm (1.9 is frankly ridiculous). Haggling in the UK may bring the price diff down to a more reasonable level.
  6. robfitzp
    robfitzp
    Dec 12, 2002
    1,162
    38
    Bristol
    +20
    Thanks both.
    Got to go and finish Xmas lunch - if I spend any more time on here today the season of goodwill will end prematurely... :)
    Merry Christmas to all.
    Rob
