M&K and 100x5r/av32r
Discussion in 'TAG McLaren Audio Owners' Forum' started by scarty16, Dec 22, 2003.
  1. scarty16
    scarty16
    Jul 1, 2003
    1,058
    +97
    Hi all
    I am considering getiing some M&K speakers after Xmas, but I noticed that they are 4ohm rated and not the more usual 8 ohms.
    I believe that I am right in saying that the 100x5r should power these quite hapilly, but can anyone explain to me if I am wrong and what if any difference 4ohm vs 8 ohm means to me.
    The M&K's are the K series and the 850 series I am considering.
    In fact has anyone got any of these and what do they think of them?
    They will have to be wall mounted, again does this make any difference?
    regs
    SImon
  2. cskates
    cskates
    Jul 5, 2001
    151
    Belfast, UK
    4ohm shouldn't be any bother for the 100x5R, my front 3 speakers are 4ohm Linns and the rears are 6ohm.
  3. cj
    cj
    Apr 6, 2001
    1,457
    Reading
    +74
    I have a 250x3R and a 100x5R driving 7 x M&K SW150s with no problems what so ever.
  4. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    The 100x5 will have no problems with a 4 0hm load as long as it's not especially reactive also....you will find they dont quite double output into steadily decreasing loads,and heavily reactive loads do make them sound a bit strained,but the M&K's should be fine.
