M&K Advice
Discussion in 'Home Cinema Speakers' started by orangemirrors, Jan 29, 2002.
  1. orangemirrors
    orangemirrors
    i'm after some advice on who sells this range ( i'm in manchester) and how they stand up. i was looking at getting B&W but i have noticed after reading posts in here that they seem to be the thing to get , i have a room of 6m x 3m and i dont have room for floorstanders this is why i noticed about M&K they seem more expensive but a touch smaller. also im really interested in tripoles this sounds like something i should have i will be running them off a yam ax1.
    any advice or comments greatly appreciated
    many thanks
  2. jspone
    jspone
    Dec 5, 2000
    89
    Lancs
    There's a branch of sevenoaks in Manchester. I was in there last week, they have a range of M&K speakers.
    Personally, I have B&W main and centre and a M&K subwoofer. Although my B&Ws are floorstanding, they do produce a number of smaller speakers.
    The thing to do is audition them. Sevenoaks also sell B&W so you can compare.
    John
  3. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    17,723
    Inbetween Upgrades !
    +6,100
    Orangemirrors,
    I have a M&K set up , comprising 3 x K7's across the front , 2 x K4's at the sides , 1 x K9 sub. I had them demo'd at Sevenoaks Manchester ( on the High street ) and also at Sevenoaks Liverpool . Their demo rooms are very different which is why i tried both.
    They are driven by a Denon 3802 and sound superb.
    My room measures 6m x 5m and they fill this space no problem, however the little K9 sub does struggle to push the air round a room this size, and it doesn,t go as low as some, albeit a very fast and well timed sub. I am now thinking of changing it, very seriously. I would only suggest you take an audition with some of your own material.
    Kev
