M&K 850s vs 150s any comparisons please
Discussion in 'Home Cinema Speakers' started by benny, Jul 1, 2005.
  1. benny
    benny
    Jun 4, 2005
    2,618
    Hartlepool
    +794
    Hi was just wondering has anyone heard the difference between the 150 and the 850, do they have the same charactheristics, maybe are the 150s less forward sounding.
    thanks ben.
  2. recruit
    recruit
    Hi Ben,
    The 850's are definitly not as good as the S-150's but not too far off, the sound stage is alot bigger and the top end is smoother but once again the better the amplification the better the sound on both set's of speakers.
    Both speakers give a very dynamic performance and are probably the best speakers for watching movies on IMO.
    Regards
    John
  3. 30CenturyMan
    30CenturyMan
    Dec 3, 2004
    760
    +47
    Most of the M&K range are quite bright in their presentation and as such they all have a very similar 'house sound'. However, if you move into their professional range things start to improve somewhat. The MPS2510 (pro equivalent to the S-150) for instance, uses a slightly different tweeter array and has a smoother presentation than the S-150. They are more expensive though. :)
  4. recruit
    recruit
    Scott3 - The MPS2510's actually work out cheaper than the S-150's individually, and they only come as a standard square front with no choice of angled presentations like the S-150's do.
  5. 30CenturyMan
    30CenturyMan
    Dec 3, 2004
    760
    +47
    I was thinking of the active versions when I mentioned the price. :oops:
    However, if the 2510 (passives) are cheaper than the S-150 (passives) then I would go for the 2510 everytime, especially considering the slightly better tweeter arrangement.
  6. recruit
    recruit
    I nearly bought the passive 2510's but settled with the S-150's as i wanted the angled fronts plus i worked out a good deal :thumbsup:
  7. recruit
    recruit
    Benny - What did you choose in the end? did you keep the 850's or did you change to the S-150's
