M&K 750thx or k7's
Discussion in 'Home Cinema Speakers' started by rigs, Apr 16, 2004.
  1. rigs
    rigs
    Apr 16, 2004
    57
    i.o.w
    +3
    Hi all,looking at getting some new speakers,not sure whether to get k7's across the front or pay £200 more and go for the 750THX selects.keeping my Yam DSP-a1 to run them for the time being,any thoughts appriciated.Thanks in advance for any replies.Rig
  2. Smurfin
    Smurfin
    Aug 13, 2002
    21,457
    +4,392
    Rigs
    You might want to consider what type of listening room you have, and how loud you generally listen to movies.
    The 750s are VERY bright, and this can lead to hard edges if your room is particularly reflective (lots of hard surfaces, very little soft furnishings etc) and especially if you're running the A1 at high volumes.
