M-Form mounts recommendation
omara500
Established Member
I purchased their 55-68" mount and can highly recommend it. I originally purchased what seemed to be a perfectly usable 60" mount from eBay but it wasn't big enough for my pioneer 6090 and after receiving the M-Form mount, I realised the build quality was poor - do not buy cheapy eBay mounts!
On top of an excellent product and rapid delivery, the customer service in terms of after-sales advice was excellent; I'm probably saying this because I put the mount up myself on an unusual wall and was given some useful advice.
My one:
M-Form - 55" to 68" Universal LCD/Plasma Bracket
Highly recommend M-Form :thumbsup:
ChertseyB
Established Member
Considering getting one of these for my soon-to-arrive 600A.
How did you find fixing the screws from the underside to secure the TV to the mount? It look really tricky in the manufacturers instructions.
When the TV is hanging on the mount unsecured, can the bottom edge be safely swung away from the wall a little (as illustrated in the instructions for Pioneer's own KRP-WM01 mount if you've seen that)?
And did you achieve the claimed 35mm wall spacing?
Many thanks for the info
Richard
omara500
Established Member
Hi Chertsey,
The underside screws were difficult to put in but with a very long screw driver it can be done fine.
The mount to wall clearance was just over 4cm I think.
I can't comment on trying to swing the bottom out as I didn't try it and probably won't ever need to. I managed to connect everything to my 6090 while it was mounted, although it was a bit tricky :)
Sorry I can't be more help.
ChertseyB
Established Member
Thanks mate.
I purchased the m-form mount on your oringinal recommendation, and have also found it to be an impressive piece of kit. Very happy with it.
Thanks for the info.
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
